Greetings.
Is an mpeg file generated by capture card made by company X the same standard as a file made by company Y's capture card? (settings the same in each)
I ask because I have an Adaptec VideOh! Media Center USB 2.0 that I captured video from a Hi8 camera. Win DVR 3 is the only program in existance that mates with this stupid thing and I have since discovered the program is very limited. I selected mpeg-2 in a "better" format which I believe is around 3000 bit sample rate. (if I misstate I am new to this ie dummy).
The program captured just fine and saved the files with an "mpeg" file extension.
The MyDVD and Showbiz programs that came bundled with the card are limited so I tried to pull the raw files into Pinnacle Studio 8 to splice and edit. When trying to open the file, Pinnacle's defaulted open file types do not see the mpeg files. I tried the *.all files and it will see it but not pull it in. Gives me a file missmatch error.
If I change the file extension to .mpg, Pinnacle will load it, play it but with no audio.
What could be the difference in the files? The captured files play just fine with audio an all the media players I have.
If at first you don't succeed, maybe failure is just your style.....
See if your file will demux properly into a video (.M2V) and an audio stream (.WAV or .MPA). If so, then remux them back into an .MPG file.
I suspect problems with Pinnacle if the other programs will play your files properly.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by SLK001If at first you don't succeed, maybe failure is just your style.....
I'm not able to remux those "mpeg" files from winDVR myself using TMPGenc.
Mpeg2vcr also don't open those files to fix them.
The problem is basicly on the segment files: The first one always work.
I would like to find a solution on this, winDVR is the best on terms of quality for realtime software solution with typical analogue in cards.
I end up using older versions of winDVR to solve this issue, but this is not the solution...
how to convert mkv or vob to mpg or mpeg
By ashe09 in forum Video ConversionReplies: 4Last Post: 11th Oct 2011, 04:46 -
By ashe09 in forum Video ConversionReplies: 2Last Post: 11th Oct 2011, 04:05 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Batch creation of mpg, mpeg, avis
By silentthread in forum EditingReplies: 2Last Post: 4th Jan 2008, 18:24 -
WMP11 Error on .mpg and .mpeg playback
By peebee23 in forum Newbie / General discussionsReplies: 14Last Post: 11th Sep 2007, 13:27
