Was not sure were to post this. I got a teac 516 drive to take the burden of reading dvds off my burner.
the problem is when ever i try to backup a disk with a layer break with clone dvd dvd shrink or nero recode it errors about half way thru I assume were the layer break is. With a single layer disk works fine.
The only work around is to either use my burner or dycrypt it in file mode and then transcode from hd. If I decrypt it in iso and mount it to a virtual drive it does not work either?
Any one have any thoughts?
If it is a DVD-9, I always decrypt in file then transcode with DVDShrink. Your DVD-ROM maybe faulty, the disc could have a scratch, or it might be something with your region (probably not though). Did you try more than one DVD-9? If so does it mess up at the exact same percent or area?
Adam
DVD Decrypter>DVDShrink>CopyToDVD -
Yes all dvds that are dual layer do it another guy also got the same drive and his does the same.
Try to update the firmware for your drive. If that doesnt work take it back or get a new drive (LiteOn's are pretty good bang ot the buck). Keep me posted. Best of Luck.
Adam
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
Help make my Teac DV5188 region-free
By cinnie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Sep 2010, 08:44 -
Looking for help with a Teac DV-3120 mkII
By cubepunk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Sep 2007, 01:12 -
Teac DV-H350
By length in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd May 2007, 14:32 -
Region Hack code for TEAC DV3120
By leahwatson in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th May 2007, 14:14
