OK well i am having bad pixelation problems to the point sometimes the screen goes black for a sec or two..then starts where it left off. The way I have been making my dvd9 to five are as follows. I have tried DVDXCopy Plat. I have tried dvd shrink and reauthering the to a MOVIE only mehtod. keeping only 1 6-channel audio . then burning with CopyToDVD. Either way i am still getting mild to severe pixelation in parts of every backup i have made. I wanting to make backups without EXTRA"s and some even without menu's so I am able to keep maximum vid and audio quality. here are the programs I have installed.
alcohol 120%
CCE SP Trial Version
CloneDVD
CopytoDVD
DiscJuggler
DVD Decrypter
DVD X COpy Plat
DVD X Rescue
DVDCOPY ONE
DVDREasy
IfoEdit
InstantCopy
Record Now Max
DVD2one
SmatrRipper
Ulead DVD MOvieFactory
My writer is the Pioneer A06 and I have had the same result burning the disc;s at 4x and 2x. And the pixelation has occuerd on both my stand alone players. My PC is an 1800 + AMD with 1 gig of DDR.
What am I doing wrong?? oh yeah and my media is Matrix
thx for any help you can provide. I have searched the forums and read several guides to get me this far and i would hope there would be a way to back up without pixelation
I would suggest using DVD Shrink, and using decent quality DVD-Rs.
Hello. -
I have ordered some ritek...hopefully that will cure the problems.....thx guys.....oh and I do use dvd shrink and re-author...i take out the extra's and menu's ..so my vid quality is top notch.....hopefully the media will cure all
Spend a few more cents on better quality DVDs. I use ACCU disk from Meritline, never had any disc problems only user. Also in DVD Shrink, set the preference size to custom, say 4375 MB. I find when I do get pixelation its towards the end, by putting this buffer I have eliminated the problem. Good Luck!
DVDSHRINK and RITEK is the most straight forward and highest quality method.
pixelation during compression
By asiafan in forum Blu-ray RippingReplies: 2Last Post: 26th Feb 2011, 11:29 -
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 13:52 -
MKV pixelation
By Nicely in forum Video ConversionReplies: 4Last Post: 6th Apr 2010, 12:31 -
Pixelation Problem
By Renta in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 22:46 -
disappearing pixelation
By AlecWest in forum Off topicReplies: 5Last Post: 29th May 2007, 09:24
