    Nov 2003
    Ottawa, Canada
    How do you guys measure how many frames you drop when capturing? If you use Video Studio 7 (for example), I don't see where you can find out how many frames you drop. Please tell me what software tells you and where when you drop frames.
    Thanks!
    Feeling gratitude and not expressing it is like wrapping a gift and not giving it.
    Apr 2002
    The State of Frustration
    If you like using Video Studio (I do not blame you), you can still see how many dropped frames your system has during cature. Zetti found this procedure:
    Originally Posted by Zetti
    Hi boys,
    To have drop-frame counter in VideoStudio 7, here's workaround to make it
    come back.
    Please follow the steps below:
    1. Locate HerCap.ini file in the C:\Documents and Settings\All
    Users\Application Data\Ulead Systems\Ulead VideoStudio\7.0
    2. Open HerCap.ini file and add "ShowFrameNumber=1" below [CAPTURE_SETTING]
    section.
    EXAMPLE :
    [CAPTURE_SETTING]
    ShowFrameNumber=1
    3. Close and Save the ini file.
    4. Launch VideoStudio 7 and go to Capture stage, you will see the drop frame
    counter.
    Note: 1024x768 display area will make the drop-frame counter not show very
    well on the Option Panel; however, you still can see it. The drop-frame
    counter will be showed completely when the display area is changed to
    1280x1024.
    Have fun,
    Zetti
    Hello.
