I have got many AVI divx files that i want to convert to mpeg2 so i can burn them to dvd. i am encounting a problem though. i have used many different conversion tools includiong tmpenc but every time i convert i get the picture but no sound. could anyone help me please
Many thanks
Stick with TMPGenc, but try this.
1. Convert the AVI audio to wav using Virtualdub by going to the Audio menu and selecting "Full Processign Mode". Then go to File and select "Save WAV".
2. Using the DVD specs in TMPGenc, make sure you select the wav file as your audio source.
3. Make sure the setting in the lower right corner of the screen look like this:
Post back if you have any problems. -
I am by no means an expert at this, however I have converted over a hundred divx and xvid files to svcd. First make sure that you have the proper video and audio codecs installed. Then follow the conversion method written by LeeBear which can be found on this site. Unless the file has a corrupt header or is an improper framerate, it seems to work well every time.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
DVD to avi/DivX
By nempo in forum DVD RippingReplies: 4Last Post: 6th Apr 2010, 21:47 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 17:28 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 14:20 -
Which is best app for DVD to DivX or AVI....?
By snadge in forum Newbie / General discussionsReplies: 26Last Post: 1st Feb 2008, 11:14
