Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    England
    trying to backup certain dvd's with dvd shrink i get message saying dvd shrink encountered problem failed to read file D:\ copy protection error the read failed because sector is encrypted. i can't get the same dvd's to copy using dvd x copy express. can anyone give me any advice on how to get round this.
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Are you decrypting the dvd first using dvd decryptor or another ripper?
    What We Do In Life, Echoes In Eternity....
  3. Use AnyDVD to bypass protection.
    Not sure if it works with Shrink but it works with Instantcopy, CloneDVD etc.
    Removes Macrovision and Region Protection.
    Hope this helps.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Rip with smartRipper or DVD Decrypter.
    If in doubt, Google it.
