I am converting DIVX files from AVI to SVCD.
I have managed NTSC (23FPS) to PAL(25FPS) using "frameserver" thanks to advice from you guys and the quality is pretty good when i have put them on DVD-r.
Now i want to convert NTSC (29FPS) to PAL(25FPS) but have read that its best to "Forget it".
2 Questions:
Question 1 : Is it possible?
Question 2 : If so will it be "jerky" or can it be done to give quality result?
Thanks for any input.
Pal 25i to Ntsc question
By spiritgumm in forum Video ConversionReplies: 17Last Post: 15th Dec 2011, 18:16 -
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 21:59 -
Simple click and go method to convert PAL to NTSC
By THRobinson in forum Video ConversionReplies: 15Last Post: 26th Feb 2011, 00:16 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 09:53 -
A short, simple, answer about core 2 CPU and DDR2 memory
By DB83 in forum ComputerReplies: 5Last Post: 9th May 2008, 19:59
