I Recently purchased a Panasonc DMR-HS2 to record from Digital terestial TV but when i connect my SONY Reciever with SMARTLINK to the hs2 using the av2 socket the q-link function does not work. If i connect to av1 on the hs2 it works ok but leads to other problems as that socket is for the tv. Is this a fault with my unit or has anybody else had this problem.![]()
I didn't know that Panasonic have this kind of function. Can you point me to correct part of manual ?Originally Posted by grantwalshPinnacle Studio 8 and DV home video editing (ver.9 already home)
Q-Link and smartlink are the same thing. I should be able to set my set top digital reciever to start and stop recording on my hs2 and download prgramme titles. My Sony set top digital reciever has this function(SMARTLINK) and the panasonic has ("Q-LINK). this feature does work when i connect to av1 on the panasonic but not av2 as it suggests i do in the manual page 14 of dmr-hs2 manual. maybe the dmrhs2 av2 scart socket does not support Q-link or smartlink.?
Now I see... Your is EU (UK) version and I was reading US manual
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 15:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 13:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 23:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 16:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 03:12
