I bought a 10 pack of DVDs from walmart. So far 3 of them have coastered. 3 have worked. Im thinking of returning them but of the 3 I have used I have used to back up a few movies. Dont really feel comforable returning boarderline illegal backups. Sure I think that its legal to backup copies of your own movies. Which they are. Im not sure if the letter of the law makes it legal. Is there anyway to destroy a DVD using software? Reburn it to destroy it. If that makes sense. I doubt there is. Maybe I should just replace the 3 used ones with 3 other blank DVDs. They are the same general brand. Memrex though not the exact same. Maybe I should just cut the lose and hope the next 4 work well. 70% is not such a bad ratio.![]()
I wouldn't risk returning blank DVDs with some movies burned on there "illegally". You just never know what would happen if they did want to "make an example" of you. Just take the loss and move on, but saving yourself a couple of bucks at the risk of getting in trouble for piracy is not worth it.
No such thing as borderline illegal. Either it is or it isn't. If they're really your movies, then you're clear...Originally Posted by K(c)offee
...but if you plan to return used DVDs to Wal-Mart and tell the employee that it's okay because they're "legal backups" then please tell me when and where you're going to do it. That's something I'd seriously like to see up close.
(and all kidding aside, unless you can prove that the media is defective, which you aren't so don't even try it, I can't imagine them even considering letting you return them.)
Copy "Gigli" to it.Is there anyway to destroy a DVD using software?
And risk getting the cops called for fraud? Don't. It's not worth it.Maybe I should just replace the 3 used ones with 3 other blank DVDs. They are the same general brand.
And don't forget that it might not be the media. There could be other reasons your burns are screwing up.Maybe I should just cut the lose and hope the next 4 work well. 70% is not such a bad ratio.
Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
Returning my Canon HF-R21 (But what should I replace it with?)
By Obtong in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2011, 14:10 -
Blockbuster returning from the Dead?
By 16mmJunkie in forum Latest Video NewsReplies: 53Last Post: 9th Apr 2011, 21:30 -
returning to the scene: need to transcode xvid/divx for psp
By cmwill84 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 04:10 -
I'm returning as a Moderator. tgpo is back!
By tgpo in forum Off topicReplies: 12Last Post: 2nd Apr 2009, 18:25 -
Mandvd Returning Errors- Any Suggestions
By chiques in forum LinuxReplies: 0Last Post: 17th Dec 2007, 10:16
