Hi,
I have been using DVD Shrink 3.0 beta5 and Nero 5.5.10.54 with my NEC 1300A drive under window 2000 without any problem. However when I installed the new DVD Shrink 3.12 and tried to do a direct backup. The "Burn with nero" drop dowm menu only showed "image recorder" and "hard disk folder". I used regedit to check the registry under DVD Shrink 3.12 the target device also only showed "image recorder". I uninstalled and reinstalled the program, no effect. I also tried 3.11, same problem. Is there anyway to make DVD Shrink recognize my NEC 1300A drive? I can still backup to hard disk and burn with nero. But it will be nice to do it directly. Thanks!
cchang
just did the upgrade to 3.1.1 and had same problem when using internal pioneer 105 to read dvd and wanting to use usb-nec for burn.
when used nec for both it worked, but had to be at pc to remove source sisc and put in blank
attempt to read from nec & record to pioneer over-night did not work
Still trying -
Hi,
DVD Shrink can rip DVD using the NEC 1300a drive. It just does not recognize the drive under Nero direct burning option. All the other programs, TPMG DVD author, Movie Factory,neoDVD worked fine with the drive. Thanks!
cchang -
Hi,
According to DVD Shrink web site:
http://forum.digital-digest.com/showthread.php?s=1f7cdbe582b53d2ffb52f52269cee35b&threadid=30800
5.5.10.54 should work. Some versions work, some versions do not. It seems there is no patten at all.
cchang -
my results update ver 3.1.1
interal pioneer 105
external usb nec 1300a
placed blank media in nec
source dvd in pioneer
dvdshrink 3.1.1 backup & burn-sees nec
working folder: vidrip# (two sub folders-audio_ts and video_ts) video_ts folder selected.
come back in 3to4 hr, all done. GREAT
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
DVD Shrink won't recognize Nero(New PC with Windows 7 64 bit)
By Jonathan in forum DVD RippingReplies: 19Last Post: 1st Jun 2011, 08:41 -
dvd fab wont recognize target burner drive
By lauraji in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2009, 00:34 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
PC drive does not recognize DVD-Video disc
By niko84 in forum Software PlayingReplies: 4Last Post: 17th Sep 2007, 19:44
