I have been looking at getting the fuji TAIYO YUDEN 4X DVD-R MEDIA and the maxell brands from reading on these boards. Great media, but the extra protective layer from these TDKs sounds great!
Just wondering if they are just as good as the Riteks, fuji, and maxell dvd-rs?
Don't want to spend $40 for a 10 pack and here they suck. lol. I've read some reviews on the dvd media section on the left and the TDK armor plated dvd-rs sound reliable. Just hoping to get any more views on this media.
Unless you eat your dinner off of your discs, or cut carpet on them to save your hardwood flooring, I'm not convinced they're any better than other discs with a coating on the top - like inkjet printables, glossy white topped etc.
I have yet to write off a DVD due to top surface damage (CD-R's are another matter), and I tend to use regular media with just a plain old silver top. Just put them back in the case when you're not using them and don't whiz them around the place like a frisbee and you should be OK, right ?
Gold Plated Vs Normal Cables
By amira in forum Capturing and VCRReplies: 19Last Post: 15th Nov 2011, 14:02 -
Why do scifi bad guys never have security cameras and wear armor?
By yoda313 in forum Off topicReplies: 6Last Post: 10th Apr 2011, 15:44 -
Anyone tried or had good luck with these TDK Dual Layer discs?
By terryj in forum MediaReplies: 2Last Post: 14th Feb 2010, 05:02 -
Is TDK's RICOHJPN-D01-67 good Media?
By TBoneit in forum MediaReplies: 2Last Post: 5th Aug 2007, 20:18 -
TDK brand DVD+Rs- These any good?
By Super Warrior in forum MediaReplies: 12Last Post: 28th May 2007, 15:19
