I have just started burning my home videos to DVD. I use a DVD+R/RW Drive. I have a Panasonic DVD Player.
I am using the trial version of NeroVision. The first time I burned one of my home videos which was created using Windows MovieMaker, it was fine and played on my DVD player. It was 7 minutes long. Bitrate high quality 9716 bps.
My second project was a 30 min home video, 1.8 GB. When I used the Nerovision, I created chapters and also applied high quality bitrate. The problem is that it doesn't play on my DVD player. I can see the menu screen with all the chapters. When I press play, it highlights and does not play.
I am really puzzled. I have tried to decrease the bit rate butI don't think it's related. It can'tbe the DVD player cause it played my first project . In fact the quality is great.
Thanks I look forward to some answers.
By the way, before this happened, I was actually able to successfully burn a 40 min home video. But that was onlyonce. So I can't understand. Is it possible that trial versions have limits to lengths of dvd's you can burn?
What burner? What media? It helps if you give more information regarding the hardware as well as the fault.
Artificial intelligence is no match for natural stupidity. -
I have an Hp Pavilion t380 model.
Pentium 4 2.8 Gh 200 MHS Busspeed
RADEON 9200 sec video
HP DVD Writer 300n DVD+R/RW 40xR 16xW
I used a TDK DVD +RW and also tried with LASER DVD +RW -
Hmmmm! Are you sure that the HP is a DVD burner, the reason I ask, is that I very much doubt that any burner yet has a 16X write speed. I'm aware that the newest generation have/will have 8X burning.
That aside I don't have any experience of +R discs but it may be worth trying another make of disk. Perhaps someone else with more experience can suggest a suitable alternative. ANYONE?Artificial intelligence is no match for natural stupidity. -
Highlight the video or chapter then instead of pressing play, press the enter key. This is what I had to do when authoring with Nerovision.
to the duchess: that was my cd writer, thedvd burner is 4x write 8x read.
to kurt s: it tried that already but doesn't work.
thanks everyone, i think i'll try another software.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Dolby problem in Nerovision 3
By SuperJman in forum EditingReplies: 1Last Post: 3rd Dec 2008, 04:13 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39 -
NeroVision problem
By Flying Doctor in forum Authoring (DVD)Replies: 10Last Post: 23rd May 2007, 00:52
