Hi,
I am using vcd cutter 4 to convert my dat files into mpg files. But i have to select the source one by one. I was wondering if there is a software that allows me to convert all the dat files that i have into a folder to mpg file formats...Please advice, thank you!
Warm Regards,
Jacky -
ive havnt needed to this much but the couple of time i did i just renames to files, now im sure there as to be something wrong with doing this but it worked for me, to do what i was doing, as a side note the original mpg files were changed to dat by nero when i burned the vcd
i think you didn't get my idea. I'm not burning this. I'm doing the other way round. I want to convert from dat to mpg. And instead of selecting one by one, i want to be able to select all at one shot!
please advice!!!Warm Regards,
Jacky -
i found my software , thanks to all for their time to help me!!!
For those out there, maybe you'll need this in the future, the name of that software is Etymonix Media Raider!
Adios~Warm Regards,
Jacky
Join multiple series of mpg files?
By Chasden in forum Newbie / General discussionsReplies: 17Last Post: 18th Sep 2014, 05:43 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
