  1. Ok, so I've had a DVR-103 (Compaq) for a couple years now and just decided to start using it to write DVDs. Before doing so I upgraded the firmware to v1.90. I created my first DVD with no problems at all. Works flawlessly. I go to burn a 2nd one today and I get nothing but errors. Not matter what I do it will not write. Yet It still plays DVDs, and still writes CD-Rs and CD-RW with no problem. Has anyone else had this problem and know how I can fix it. This is the log of the error Nero gives me. I've tried other programs to write DVDs and it errors out on all of them.
    Error Log:
    1A23-0071-4030-1405-0958-5389
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 7:06:00 AM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 11/11/2003 2:49:52 PM
    Nero version: 6.3.0.0
    Recorder: <PIONEER DVD-RW DVR-103> Version: 1.90 - HA 1 TA 0 - 6.3.0.0
    Adapter driver: <atapi> HA 1
    Drive buffer : 2000kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <PIONEER DVD-RW DVR-103 >Version: 1.90 - HA 1 TA 0 - 6.3.0.0
    === Scsi-Device-Map ===
    DiskPeripheral : WDC WD800BB-60CCB0 atapi Port 0 ID 0 DMA: On
    DiskPeripheral : Maxtor 6Y080P0 atapi Port 0 ID 1 DMA: On
    CdRomPeripheral : PIONEER DVD-RW DVR-103 atapi Port 1 ID 0 DMA: Off
    CdRomPeripheral : IOMEGA ZIPCD 4x650 atapi Port 1 ID 1 DMA: Off
    === CDRom-Device-Map ===
    PIONEER DVD-RW DVR-103 G: CDRom0
    IOMEGA ZIPCD 4x650 F: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 74448896 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 511MB (523568kB)
    Free physical memory: 189MB (194248kB)
    Memory in use : 62 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    12.1.2004
    UDF/ISO compilation
    10:35:28 PM #1 Phase 112 File dlgbrnst.cpp, Line 1800
    DVD-Video files reallocation started
    10:35:28 PM #2 DVDREALLOC -22 File DVDVideoCompilation.cpp, Line 1160
    File 'VIDEO_TS.VOB' is not referenced and should not be present
    10:35:28 PM #3 Phase 115 File dlgbrnst.cpp, Line 1800
    DVD-Video files reallocation failed
    10:35:49 PM #4 Phase 132 File dlgbrnst.cpp, Line 1800
    DVD-Video files compliance ignored
    10:35:49 PM #5 Text 0 File Isodoc.cpp, Line 6029
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : TRUE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet :FALSE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    10:35:49 PM #6 Phase 111 File dlgbrnst.cpp, Line 1800
    DVD-Video files sorted
    10:35:49 PM #7 Text 0 File Reader.cpp, Line 118
    Reader running
    10:35:49 PM #8 Text 0 File Writer.cpp, Line 124
    Writer PIONEER DVD-RW DVR-103 running
    10:35:49 PM #9 ISO9660GEN -11 File geniso.cpp, Line 3882
    First writeable address = 0 (0x00000000)
    10:35:49 PM #10 ISO9660GEN -11 File geniso.cpp, Line 3882
    10:35:49 PM #11 Text 0 File Burncd.cpp, Line 3094
    Turn on Disc-at-once, using DVD media
    10:35:50 PM #12 Text 0 File DlgWaitCD.cpp, Line 239
    Last possible write address on media: 2298495 (510:46.45)
    Last address to be written: 2173375 (482:58.25)
    10:35:50 PM #13 Text 0 File DlgWaitCD.cpp, Line 244
    Write in overburning mode: FALSE
    10:35:50 PM #14 Text 0 File DlgWaitCD.cpp, Line 2068
    Recorder: PIONEER DVD-RW DVR-103, Media type: DVD-R
    Disc Manufacturer: LONGTE - N 001
    Disc Application Code: 64, Disc Physical Code: 193
    10:35:50 PM #15 Text 0 File DlgWaitCD.cpp, Line 405
    >>> Protocol of DlgWaitCD activities: <<<
    10:35:50 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 779
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2173376 (2173376) = #2173376/482:58.26
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2173376 blocks [PIONEER DVD-RW DVR-103 ]
    10:35:50 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 948
    Prepare recorder [PIONEER DVD-RW DVR-103 ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4451074048, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2173376 | lead-out | 1 | 0x00 | 0x41
    10:35:50 PM #18 Phase 24 File dlgbrnst.cpp, Line 1800
    Caching of files started
    10:35:50 PM #19 Text 0 File Burncd.cpp, Line 4061
    Cache writing successful.
    10:35:50 PM #20 Phase 25 File dlgbrnst.cpp, Line 1800
    Caching of files completed
    10:35:50 PM #21 Phase 32 File dlgbrnst.cpp, Line 1800
    Simulation started at 1x (1,380 KB/s)
    10:35:50 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2264
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    10:35:50 PM #23 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 13:29,574 (809574ms) -> OK
    10:35:50 PM #24 Text 0 File DVDR.cpp, Line 1424
    Recording mode: Sequential Recording Mode
    10:35:50 PM #25 Text 0 File Mmc.cpp, Line 19397
    Set BUFE: supported -> ON
    10:35:50 PM #26 Text 0 File DVDR.cpp, Line 1539
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    10:35:51 PM #27 Text 0 File Cdrdrv.cpp, Line 7912
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 0 h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    10:35:53 PM #28 Text 0 File Cdrdrv.cpp, Line 1276
    22:35:53.803 - PIONEER DVD-RW DVR-103\H1 T0 : Queue again later
    10:38:06 PM #29 SCSI -1135 File Cdrdrv.cpp, Line 1430
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07E00000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x60 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x03 0xFF 0xFF 0xFE 0x00 0x0E
    0x00 0x00 0x00 0x00 0x0C 0x00
    10:38:06 PM #30 CDR -1135 File Writer.cpp, Line 301
    Write error
    10:38:06 PM #31 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    10:38:06 PM #32 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    10:38:06 PM #33 Text 0 File DVDR.cpp, Line 1743
    EndDAO: Last written address was 607
    10:38:06 PM #34 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 0:00,000 (0ms) -> OK
    10:38:06 PM #35 Text 0 File dlgbrnst.cpp, Line 1658
    10:38:56 PM #36 Phase 34 File dlgbrnst.cpp, Line 1800
    Simulation failed at 1x (1,380 KB/s)
    Existing drivers:
    File 'Drivers\CDRALW2K.SYS': Ver=5.1.0.209, size=23721 bytes, created 7/1/2003 9:17:46 PM
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 3:27:50 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Cheap Media. Try another brand, or work through the pack until you find one that works.
    You may want to update to firmware 2.00, as it is the newest available. Though 1.9 did fix some problems with 4x media, 2.00 cures most of them.
  3. Thanks for the help. I've tried upgrading to firmware 2.0 a couple times. But it never works. The only one available is 1.9 from compaq's website. I got 2.0 off another website and recieved this msg.
    /// DVD-ROM/DVD-RW Firmware Update Utility Ver1.25C
    Start updating the device No.1.
    Current Revision>> PIONEER DVD-RW DVR-103 1.90 02/06/05
    Model name of kernel part is not macthed.
    0drive(s) have been updated successfully.
  4. I have exactly the same problem. I upgraded my drive to 1.90 as well and now I cannot upgrade to firmware version 2.0 neither can burn any DVD. I have tried Nero and Roxio both. I use maxwell DVD-R, I payed $15 for 5disks, so this is not cheap media. Any one knows what could be the problem.
    Thanks,
  5. AS soon as you screw with your firmware you're cooked. That's the problem. About 30% of the problems reported on this forum result from people flashing their DVD burner firmware.
    Look around and see if you can find a utility to downgrade your firmware back to what it was. Never ever ever ever ever upgrade or hack your firmware. It's just not worth the hassles.
