Hello all,
i have another simple question, I hope. This past weekend I upgraded to Win XP home from Win 98SE. That is not my problem. Here it is:
When I was using WIN 98 my dial-up modem did not make any noise when it connected to the web. No dial tone, dialing, nothing. Now that I upgraded to XP the modem is making noise again. Is there anyway to turn it off? I'm not too familiar with the workings of XP yet.
Thanks in advance,
Mike
In classic veiw I think it's:
Start
control panel
modems
uncheck - play sound when dialing or it's under the sound control panel -
In modem properties, you should have a slide bar that increases-decreases the volume. Personally, with dial up, I liked to hear the modem talk to the other machine, at least I know it has dialed out.
Cheers,
George -
808smokey
Thanks for the reply. It works and now it is all quiet again!! I personally don't care if it is on or off but when you have a 21 month old daughter across the hallway napping, I can use every opprotunity to keep things quiet.
Mike
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
New modem - DOCSIS 3.0, anything I should know?
By Xylob the Destroyer in forum ComputerReplies: 1Last Post: 5th Dec 2009, 21:13 -
canot connect to modem
By romanstopme in forum ComputerReplies: 5Last Post: 17th Dec 2008, 13:39 -
Which modem router to get?
By Tbag in forum ComputerReplies: 3Last Post: 1st Jun 2008, 17:54 -
Vista modem drivers.
By Poppa_Meth in forum ComputerReplies: 5Last Post: 1st Nov 2007, 11:32
