Yes.Originally Posted by techgeek
It is more like different wrapper type. Each DV AVI have to be type1 or type2.Originally Posted by techgeek
It will read DV (decode) and re-encode it to new file type (codec). Re-encode = loss.Originally Posted by techgeek
Just capture in DV AVI. It is just data copy. Capturing (encoding/conversion) is done by ADVC-100 before it hits PC.Originally Posted by techgeek
Results 31 to 43 of 43
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
You might want to read this too
https://www.videohelp.com/forum/viewtopic.php?t=155686Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
donpedro, this topic and the one you pointed me to have really helped. I think I got it but just one more time for myself.Originally Posted by donpedro
When the DV is sent over the firewire it is written into the avi file with no loss (as long as I dont pick one of those options to switch it to a different file format where loss would then occur). Now the avi file whether type1 or type2 has the same DV content in it; the DV (or candy as someone said) is in the wrapper but slight variation of the wrapper whether type1 or type2 (1 stream or 2 streams, maybe different avi file size but either way no loss has occured). At this point the DV/candy is the same as it was before it left the capture device via the firewire cable, ie. no loss has occured.
The DV in the avi container (the candy in the wrapper) is on the PC and ready for various possible transactions.
It is these later transactions (viewing, editing, converting to another format, etc) where the video/audio data is retrieved from the wrapper and I suppose depending on how it is retrived (which codecs used, is it converted to some other format, etc) where some loss can occur.
I feel the first two paragraphs are close to what I have been reading and I think the 3rd is where depending on what I want to do true video/audio content, loss can occur. Is this right? -
Hmm... not sure if you can call it loss. I would rather call it difference. Yes. There will be difference when you add (for example) text to video and save it again as DV AVI.Originally Posted by techgeek
When you are converting there is an loss anyway. Not sure if playback/conversion is affected by codec though. I would think that only save (encoding) will make difference. But I might be wrong on this one.
As far as canfy goes.... type1 and type2 describes where is filling :P inside or on top :P (just trying to be funny)Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Well I learned a lot this week.Originally Posted by FOO
Thanks for your explanation.
OK. I've read through this post and all subsequent links. My capture from a VHS-C through my ADVC-100 is the same data regardless if I use Scenalyzer, WinDVD, or DVIO. The codec makes no difference. Right?
At what point DOES the codec come into play? Is that only when I'm viewing it on the computer?
I've captured with DVIO, which only gives the option of TYPE 1 or 2, no codec. Isn't there a tool to show me what codec it's using?
The light is finallying dawning on me regarding this. (I hope
Right.Originally Posted by Nick Burns
At what point DOES the codec come into play? Is that only when I'm viewing it on the computer?Originally Posted by ZippyP."Art is making something out of nothing and selling it." - Frank Zappa -
Transferring DV via firewire to your PC is exactly that. Transferring... copying of digital data. There is no recompression stage.Originally Posted by Nick Burns
However, rather than dumping raw bits onto your HDD, most capture programs organise that digital video data into a form that is useful -- i.e., in an AVI container be it Type 1 or Type 2.
You don't need a codec to write the raw data as a Type 1 or type 2 AVI file (e.g., DVIO).
However, the raw digital video data is still compressed/encoded in the DV compression format. So if you want to UNDERSTAND (i.e., view) the data, you need a DV codec.
Here's an analogy.
If I only understand English, I can still receive (transfer) a message in Spanish via a telephone by writing down each letter at a time into a book (AVI container). However, if I want to understand what the message actually means, I still need a Spanish interpretor (codec).
You need a DV codec to be able to do anything with the transferred DV video.
Regards.Michael Tam
w: Morsels of Evidence -
...and when you edit and resave it in DV Codec or sending back to tape. You need codec for that too.
I need to discuss/question one item that I don't think was specifically raised (I hope I'm not out of the scope of this forum): the quality difference between a DV AVI file and an UNCOMPRESSED AVI file when your source is analog (i.e. from VHS). Being a newbie, please correct me if I'm wrong, but in trying to create the highest possible quality MPG (and I am a stickler), here are my steps, and results:
I have a Pinnacle AV/DV capture card along with the Studio 8 software, and also have Ulead capture software. Both capture analog to an AVI file; however, Pinnacle only captures up to DV quality, whereas Ulead will let me capture to a much larger uncompressed AVI file.
So now I had to figure out which combination of source files and rendering software yielded the best results. Ulead did poorly regardless of the source file (seems to create slight vertical lines). Pinnacle was better, but I wasn't sold. I decided to try TMPGenc and in every test it did a better job.
Regardless of what software I used to render, I found the following to always be true: going from uncompressed AVI to MPG gave a better picture than DV AVI to MPG. It seems to make sense, since capturing to DV is one compression step, and then to MPG is a second compression step. I just assume use TMPGenc to perform one compression from the uncompressed AVI to MPG. I will say that the DV AVI still looked very good, but not as good. Again, this is for those who are trying to achieve the absolute best MPG…for many, the difference may be slightly noticable, but negligable…especially when you consider how huge these uncompressed AVI files can get!
I hope this helps; I also welcome feedback from the experts to either support/dispute explain this technically. Thanks. -
A correction on my last post: I discovered that the Pinnacle software I'm using DOES capture to an uncompressed AVI --I had to choose the last "custom" setting (it was either YUV or YUY1).
In comparing it to the Ulead AVI of the same source/length, it tends to be slightly smaller (yet another variable to wonder about), it has the same number of frames but the number of samples is slightly less. I'm thinking this has an insignificant affect on the final MPG, as I converted both to MPG and could see no apparent difference. Does anyone know if there is any significance to the different size AVI files? Thanks.
Resizing Source and Compressed Video
By ZZen in forum EditingReplies: 3Last Post: 9th Jun 2009, 08:17 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 02:19 -
Need help capturing video via Firewire from JVC DR-DX5S to Mac Mini.
By Cyrax9 in forum MacReplies: 5Last Post: 6th Jan 2008, 18:21 -
HELP!!! video being rejected by youtube after i compressed it!!!!
By sharmine in forum Newbie / General discussionsReplies: 11Last Post: 19th Sep 2007, 14:59 -
Video is "blocky" when capturing DV via firewire
By kongla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Jun 2007, 04:27
