  1. I have looked all over the web and have not found out how to add an overture to my dvd with adobe encore. Can it be done?
  2. overture meaning?
    if you want to create a main menu with encore you can.
    if you want to create an intro movie you can also
    check the newsgroups at adobeforums.com
    didier
  3. Yes I would like to add an intro movie before the menu.. Thanks for your help I will check there.
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    For an intro movie you make a timeline with one audio and video track just like you would your normal feature. You can then right-click on the timeline in the asset bin and select "First Play" making this asset the first thing to play when the DVD is run. Make sure to set an end action item in the timeline info box so that it goes from that to a menu or something when it is done playing the intro.
  5. Thanks for the help I was able to get it to work thanks again
