I have been using IsoBusters to convert bin and cue files to mpegs.
But I often run into the problem that after I have downloaded a movie it has no cue file, so I cannot covert it.
Can anyone let me know if there is a reason why I often get no cue file. And is there a way to covert to mpeg without the cue.
Thanks!
You don't actually convert the bin to an mpg. The bin file contains the mpg file as well as other files. You are only extracting the mpg file. All the cue file does is point isobuster to the bin file. You can just point isobuster to the bin yourself, cue is optional with extracting anyway.
I have tried dragging the bin alone directly into IsoBusters and everytime I do that an error pops up saying I need "______" file to continue.
Thanks! -
Sorry. I think I may be having problems because the file is corrupt, but I'm not sure. Going to keep trying.
Thanks! -
Try VCD gear this tool is free and does the job, it also fixes mpeg errors
while extracting the mpeg.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
