I am a newbie and dont know if this is the right place to post, but I need some quick help here.
I need to a dvd program to copy/backup my real dvd's. I also want to be able to create my own DVDs by video I import in.
Please give me some advice and Pros and Cons? DVD X copy platinum? Nero? DVD CLone?
Results 1 to 10 of 10
no offense ... but have you looked around this site first ....??
there are like 10,000 posts on this subject as well as guides and how to do it all ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Well since there over 100,000 posts on the site and I posted that I needed this info quickly I thought this would be the fastest.
for a quick backup DVD SHRINK and Nero 6 and while your backing up take a chance to read round the forums and guides for your prefered software / method
It appears that the CPU was operating so fast that it began to execute instructions before they arrived. This execution of future instructions created a small tear in space-time itself through which part of the cpu passed into a parallel universe -
Firstly, sorry to be a broken record, but make sure you read the forum rules - ..."chances are, someone has already posted your problem..."
Secondly, there are a number of guides which all use different programs. The best method is the one that works for you.
IMHO, Smartripper/DVD Decrypter, DVDShrink and Nero do all my jobs.If in doubt, Google it. -
Sigx97 - you might loose the advertising signature.
Panasonic DMR-ES45VS, keep those discs a burnin' -
If you want a program that backs up your DVD's easily DVD X Copy works very well. It will add a disclaimer to the DVD that says it is a backup.
If you want to have some control over the final DVD as far as what is included and how much things are compressed and if you don't want that disclaimer and if you don't want to spend any money and if you don't mind learning through research, trial and error then start do some research on DVD shrink and learn to use it. (It's easy) -
Originally Posted by sigx97
TMPGEnc DVD Author is my tool of choice for authoring. It really depends whether you are a real NOOB or whether you can pick things up pretty quickly. Most one step commercial software is written for NOOBs so you might want to spend a little bit of money. However, if you are willing to do things in two or three steps for free, there are guides on this site and freeware available - you just need to do a little research.If in doubt, Google it. -
Thanks everyone! Exactly the answers I was looking for!
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Newbie looking for a video editing program similar to Windows Movie Maker
By Anonymous74 in forum EditingReplies: 3Last Post: 18th Sep 2008, 01:48
