I have a movie that I can't burn. It's in PAL format. How to I convert it to a format that Nero will burn?
Results 1 to 11 of 11
That depends. Are you in PAL land, or NTSC? What format is the video currently in? I.e. AVI, MPEP, etc.? What are you trying to make? A VCD, SVCD, DVD? We need more info before we can really help.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
DVD DECRYPTOR - RIP
DVD SHRINK - COMPRESS
NERO - BURN
Pal is not a problem (I've done it but burnt image w/ Decryptor) -
But he didn't say it was a DVD. It could be an AVI, MPEG, etc. And he doesn't say if the standard for his area is PAL, or NTSC - he may be trying to convert it from PAL to NTSC. There may be more going on here than just trying to copy a DVD, especially since this is in the "newbie/general" forum, instead of the "DVD to DVDR" forum...Originally Posted by GabeB
Zefram Cochrane
2073 -
the video is on my computer. There's no dvd I got the video from somebody. It's an avi and it even says dvd rip in the filename. I'm in NTSC land. I couldn't even get Nero to burn it in pal format either. I'm trying ato burn it onto a memorex dvd+r 4.7gb. I was going to burn it as a vcd because it was too long to be a svcd.
You need to do some conversion to it first. You can burn it using the VCD structure onto a DVD but you need to adhere to certain conventions. That is why Nero won't let you burn it. There are a number of things you could do - convert to VCD and burn on CDR, convert to SVCD and burn to a couple of CDRs, or burn as a DVD-VCD. Whatever option you choose, you will not be able to use your existing AVi - you will need to do some conversion.
If in doubt, Google it. -
There are plenty of Guides under convert on the left hand side. If you do not wish to read them I can spell it out for you:
Get the free version of TMPGEnc. Go to File > Project wizard. Select the template that suits your purpose (probably NTSC VCD). Hit start button to commence conversion. Burn the output file using Nero.If in doubt, Google it. -
Thanks for your help. Actuall, there's a ton of options that only a skilled converter would know though.
Improving a PAL video movie
By carlmart in forum Video ConversionReplies: 33Last Post: 21st Jun 2011, 04:04 -
At What Stage Do I Convert NTSC DV to Burn PAL DVD?
By Dubinvero in forum Video ConversionReplies: 4Last Post: 5th Oct 2010, 19:03 -
NTSC -> PAL same movie length?
By busta3396 in forum MacReplies: 5Last Post: 6th Mar 2010, 07:30 -
Movie looks over streched while converting PAL 4:3 to 16:9
By maass in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2009, 02:51 -
PAL DVD will burn but not play
By vhsreject in forum Authoring (DVD)Replies: 6Last Post: 5th Sep 2008, 03:07
