You can add the subtitle first and then use dvd-lab.
http://www.polarhome.com/~afonic/subdvd.htm
then
https://www.videohelp.com/forum/viewtopic.php?t=179271&highlight=ifoedit+dvdlab+srt2sup -
I have tried using the guide suggested and have run into a problem that has been racking my brain all week. Do I have to create my VOB files in IfoEdit? I have ripped some VOBs from a DVD that already have the subtitles I want. Can't I just import them into DVD Lab?
It seems kind of backwards to take VOB files, rip the subs with SubRip, demux to elementry streams and mux back to a VOB using IfoEdit
Does DVD Lab only accept VOBs with subtitles in the SUP format? I know the VOBs on the original DVD uses a different one.
Any help is appreciated. I'm at my wits end!"Can You Dig It!" -
Here is some more information. The VOBs are episodes of a Japanese anime show. Not speaking Japanese, I need the subtitles that are on the original DVD. The episodes are over 1GB each, so they are spread out across 2 VOB files. Sometimes 2 episodes are in the same VOB file so I have to use Chopper XP to get the part of the episode I want. After I rip the VOBs, I have to rejoin them using VOB Merge.
I now import these VOB files into DVD Lab. After I Compile the DVD in DVD Lab, there is no subtitle stream present.
I can only gues that after cutting and rejoining the VOB files that the substream information has disappeared.
"Can You Dig It!" -
Obrigado, a todos,
Obrigado Baldrick
E eu queria parabenizar o forum da DVD-R HELP pela rapidez nas respostas e a organização
Thank you, to all,
Thank you Baldrick
And I wanted to congratulate DVD-R HELP forum for the speed in the answers and the organization
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 10:52 -
How do I get subtitles from a DVD to put into an XVid?
By Emanef in forum SubtitleReplies: 7Last Post: 23rd Jul 2008, 13:45 -
How to put 2 DVD onto one, keeping menus?
By LCE in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2008, 02:37 -
how do i put srt file in dvd lab pro?
By oilpourer in forum Authoring (DVD)Replies: 6Last Post: 1st Jul 2007, 19:20
