I get this error when I try to open my captured AVI file from my brand new Sony TRV22 camcorder. If I can't get this to work I might as well take it back!!!!!!
Any idea how I can resolve this?
I want to do some editing to the video, and am very used to Vdub, but very annoyed it doesn't load!
Please please please help me if you can!
Many thanks
If i'm not mistaken, the DVSD codec that it needs to play the file is a mainconcept codec. What capture program do you use and also try to capture using another codec (compressor) or no compression at all.
Virtualdub will give you this error only when it cannot find the particular decompressor to open the file.MMMMMMMMMMMMM..........sprinkles -
Hello.
Thank you for replying quickly.
I think you misunderstand. The capture I have is just done in Windows Movie Maker and is the highest quality capture - DV-AVI PAL (25Mbs) 720x576 pixels 25frames per second.
It's editing this captured file i'm having difficulty with. Vdub won't load it (error depicted above).
I have a few versions of Vdub, 1.5.7, 1.5.9 and VirtualModDub, all of which cannot open the file.
However TMPGEnc CAN open the file, and I can edit the video using the settings in there, but I prefer to use Vdub so I can add a watermark to my recording.
I have searched and not found what I need. I presume it's a codec from the error, but no idea which one I need.
if only I could open the file in Vdub then it would be great -
GOT IT!
https://www.videohelp.com/forum/viewtopic.php?p=757003&highlight=camcorder+codec#757003
http://dshow.narod.ru/codec.htm - Sony DV Codec
MINTED
Admin, feel free to lock this thread now. Case closed 8)
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 11:17 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
VirtualDub can't open my mpg from camcorder
By ssalim in forum Video ConversionReplies: 3Last Post: 2nd Dec 2008, 16:46 -
error message when capturing from Hi 8 Camcorder to PC via the capture devi
By mcreigh in forum Capturing and VCRReplies: 3Last Post: 29th Oct 2007, 16:51 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
