Hey there.
I have successfully used the VCD header trick (using TMPGEnc) to burn SVCD video files that will work in my DVD player. I used MPEG tools -> Multiplex and selected the video file, burned with Nero, etc etc...
BUT... I have several other SVCDs I'd like to burn, but they have clips added on in front. These clips are banner ads for IRC channels, and are not present on the original video footage. Apparently they are seperate from the MPEG2 file I'm trying to change the header on, because when I try the trick on any video file that has this kind of a header, it ONLY tricks the banner clip.
For example: Video File A has no banner, and the header is changed no problem. Video File B has BannerB in front, and when i Multiplex it the output is BannerB, not Video File B.
How can I get access to the actual video file?
