I try to encode a Video-TS folder into a DivX movie, but it's impossible to get the right subtitles. Four languages appear in the Subtitles pallette: Danish, which gives Danish subtitles; Finnish, which also gives Danish subtitles; Norwegian, which gives Finnish subtitles; and Swedish, which also gives Finnish subtitles.
I want Norwegian subtitles, but neither Norwegian nor Swedish subtitles are possible to get. With the VLC media player I can easily choose the right subtitles. What is wrong with ffmpegX? Is there a way to fix this?
Which was your 0SEx track number? Please note that 0Sex begins numbering at 1, while ffmpegX begins numbering at 0. As a consequence, if the track number was "4" in 0SEx, it should be entered as "3" in ffmpegX. Please try.
The last time I tried, I chose all the four subtitles in OSEx, and in ffmpegX I tried all the fifteen subtitles-possibilities, so the track numbers should have nothing to say. But still there was only two Danish and two Finnish subtitles.
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 07:42 -
Solved: Subtitles wrong color after converting from DVD to avi sub/idx
By jimdagys in forum SubtitleReplies: 4Last Post: 2nd Jun 2011, 02:38 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
What am I doing wrong? AVI to DVD with srt subtitles.
By du2vye in forum ffmpegX general discussionReplies: 8Last Post: 21st Oct 2009, 12:54 -
Wrong subtitles from local disk but ok from dvd media
By aleangleico in forum Software PlayingReplies: 2Last Post: 25th Aug 2008, 11:26
