I am having trouble at the end of the dvd's that I make is this common. I use clonedvd to make them
Try setting your complete file size to be a little under the 4.38GB limit. Your problem could possibly be that you are using the entire capicity of the disc and that is why you are getting playback issues at the end of the movie. What DVDR's are you using?
SLICK RICK
Originally Posted by lordsmurf -
If you are using media of lower quality then you might experience some issues if you burn near the limit. I have been using Ritek G04 burned on a Pioneer A05 by DVD Decrypter and Nero 6 with no problems burned near the limit of the DVD.
You seem to have identified your problem (most likely)Originally Posted by kman0199
memorex are bad quality as a general rule. get some tdk, ritek, or taiyo yuden discs. prolbems will fade away.
Burned Divx movies stopping before end...
By Jeffross1968 in forum DVD RippingReplies: 9Last Post: 18th Feb 2012, 12:08 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42 -
Burner cutting off end of Divx movies
By dondford in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 00:50 -
If I purchase a low end DVD player just to watch movies....
By leftyloopy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Feb 2008, 15:02 -
burning dvd movies and everyone freezes at end
By bandit1222 in forum Authoring (DVD)Replies: 17Last Post: 14th Dec 2007, 00:06
