The long saga of getting my home movie onto DVD continues. I manage the conversion of the video from .avi to mpeg2 using the guide http://dvd-hq.info/Compression.html
I took his advise converted the .avi to mpeg2 independently of the sound because of compatibility issues with DVD players. Now I have an audio question.
From what I can gather WAV=PCM=AC3 the only difference is the file extension. Correct?
When I extract my audio from the .avi what program should I use?
Should I use PCM or AC3 file (extension?) for best compatibility with older DVD players.
What can I do to minimize syncing problems between the audio and video when I author my DVD?
I'm using (unsuccessfully) Encore for my Authoring but I downloaded the evaluation of DVD lab to join the two together. I'm hoping there will be no sync problems - any advice in advance would be helpful.
Steve
AC3 encoding can be done with besweet. MPEG2 encoding can be done with Tmpgenc or any other MPEG encoder. I use 160kbps MPEG audio for all my home made DVDs.
What can I do to minimize syncing problems between the audio and video when I author my DVD?The more I learn, the more I come to realize how little it is I know. -
When I extract my audio from the .avi what program should I use?Originally Posted by Sasi
I shoot ten or fifteen minutes of my son each month and convert to DVD, but would like to record some of him singing and archive to CDr as a conventional CD.
Will the facility within Vdub to "save wav" work with DV avi (transferred to the PC via firewire), it's still an avi, right?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by Will Hay
Originally Posted by jgandara
Hi Steve Mackay,
Check out the 30 day fully functional trial of TMPGEnc DVD Author. It's beginner friendly, and knocks out decent looking DVD's. Note: If you try TDA with AC3 audio, you won't here the audio when playing back during chapter selection - this is normal as TDA doesn't support AC3 playback - it just allows it to "pass through". However, once the DVD is burnt, the audio plays just fine.
Originally Posted by SaSi
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by bugster
W.
EDIT: 15 Jan 03
Works perfectly, just created a perfect test wav.
Thanks.
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 15:57 -
Mp4, Aac & Wav Extraction
By mahendras in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 08:27 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 15:46 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 14:45
