I want to use the Dazzle DVC II like a tv-out card, but its software won't allow avi divx. It says the file is already in use, but it is not. The "Fast Multimedia DV Player" link for this card in the vcdhelp.com review is a broken link, otherwise I would try that. Does anyone have that program or a different solution?
You can get the "Fast Multimedia DV Player" from dazzle-europe: http://dazzle-europe.com I would post the direct link, but cant get there right now for some reason. I believe its under their downloads section.
Rommel_8 -
okay, I downloaded the software, which is just a player.
How do I use TV-Out for avi divx? All the Dazzle software can output is mpeg. Is there a different prog that can be used for output? or a patch for the "Moviestar" prog?
Other products like the dazzle?
By darklink502 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Mar 2012, 22:47 -
Pinnacle Dazzle. Need help!
By s3r19lk1ll3r in forum Video Streaming DownloadingReplies: 3Last Post: 7th Oct 2010, 16:11 -
Video to Dazzle and Tv
By fellixombc in forum Capturing and VCRReplies: 1Last Post: 6th Jul 2010, 16:52 -
Problem with Dazzle
By brad1983 in forum Capturing and VCRReplies: 1Last Post: 17th Jun 2010, 13:20 -
hd tv using dazzle
By zookeeper525 in forum Capturing and VCRReplies: 12Last Post: 11th Apr 2009, 23:14
