Hey i used DVD2SVCD to make a divx file which is 700mb to a svcd.. I wanted it to 2 cd's but it made the first cd 700 mb and the other like 1.6.. what did i do wrong.. i wrote 2 cd's and 80 minutes under bitrate tab. Maybe i used wrong encoding.. I think i was using CBR..? Please help![]()
Results 1 to 9 of 9
Open your divx file in virtual dub, if you get an error message(VBR audio), you will need to decompress your audio.
Just shut up and listen dumbass -
Hmm.. Well it's not an audio problem.. I just it to be on 2/3 cd's.. cd 1 size is 700mb but cd 2 size is like 1.6?? it should also be 700 or what? I'm not very good at this.
Don't expect miracles. Optimum SVCD quality is in the 40-50 minute/CDR range.
Wrong file size is usually a sign of a corrupted AVI.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
So my 2 hours and 13 minutes long avi file is going to be on like 3-4 cd's ? or what?
3 CD's is realistic. The file that is 1.6 gigs, does it play ok? If so, why don't you just split it in 2?
dv to divx problem
By anajat in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 19:27 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 05:15
