Hi guys,
Which is better quality audio, VBR MPEG-1 Layer II Audio (MP2) or PCM audio when converting in TMPGEnc? Or is there not much difference?
PCM will be better quality assuming a good quality source as it is uncompressed. MP2 is compressed but the difference will not be noticable by most peoples ears. The problem with PCM is it will take up a large percentage of your disc space as the audio stream alone will run to approximately 10MB/min. This will obviousy seriously reduce the amount of bitrate you can allocate to your video stream.
Another option you have is to use an external encoder for your audio and encode to AC3. -
I think the latest version of besweet doesn't do that anymore, you get a message that it sucks. I asked the same question before and it's whort it if you have more than 2 channels and because it's more compressed than PCM, other than that, you would hear the same thing with PCM or ac3
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
is LPCM the same as PCM, for audio?
By runLoganrun in forum Newbie / General discussionsReplies: 14Last Post: 6th Dec 2008, 20:37 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
