  1. I used Virtual Dub to convert an avi file(Master and Commander of Far Side.avi) to Mpg. It converted nicely halfway through the movie, then at halfway it stopped because of the following error reported by VirtualDub. How can it be fix (PowerDVD plays the whole avi movie fine) ? Thanks.
    Crash reason: Access Violation
    Crash context:
    An out-of-bounds memory access (access violation) occurred in module 'divx'...
    ...while decompressing video frame 128871 with "DivX Pro(tm) 5.1 Codec" [biCompression=30355844] (VideoSource.cpp:1516)...
    ...while running thread "Processing" (thread.cpp:105).
    Thread traces:
    Thread 00000494 (Main thread)
    C:\p4root\dev\VirtualDub\source\Init.cpp(265)
    C:\p4root\dev\VirtualDub\source\Init.cpp(284)
    C:\p4root\dev\VirtualDub\source\Init.cpp(302)
    C:\p4root\dev\VirtualDub\source\Init.cpp(365)
    C:\p4root\dev\VirtualDub\source\Main.cpp(208)
    C:\p4root\dev\VirtualDub\source\Main.cpp(231)
    C:\p4root\dev\VirtualDub\source\VideoSource.cpp(58 8)
    C:\p4root\dev\VirtualDub\source\VideoSource.cpp(61 6)
    C:\p4root\dev\VirtualDub\source\Audio.cpp(593)
    C:\p4root\dev\VirtualDub\source\Audio.cpp(599)
    Thread 000000c4 (FastWriteStream)
    Thread 000000cc (Processing)
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator BJ_M
  2. Originally Posted by torex88
    Crash context:
    It is the divx codec, being used by virtualdub, that is crashing, not virtualdub itself.
    Try scanning the avi file for bad frames.
  3. Member SaSi's Avatar
    Jan 2003
    Hellas
    Try de-compressing the video up to frame 128800 to another AVI using a better behaved codec (hufyuv if you have space). Then frames 128801 ~ 128899 and then 128900 ~ end.
    You may encounter a crash decompressing the "problematic" section. Try subsections of it including the offending frame. You, may on the other hand, encounter not problems. Perhaps DivX is choked by the lenghtly AVI and crashes.
    I've encountered this with several AVI Captures I've compressed to DivX 5.00 for archival and played back with 5.11. The work around above solved my problem.
    The more I learn, the more I come to realize how little it is I know.
  4. Hello, does anyone have any solution to the problem listed?
    I have the same problem with this one file I'm trying to convert from .avi to .mpg using virtual dub and tmpenc.
    I need virtual dub so I can also hardsub the file, but at a certain point, it keeps on crashing
    Here's what it says:
    Crash context:
    An out-of-bounds memory access (access violation) occurred in module 'xvidcore'...
    ...while decompressing video frame 9738 with "XviD MPEG-4 Codec" [biCompression=44495658] (VideoSource.cpp:1567).
    I'm really new to all this, so I'm not sure how to follow the instructions sasi posted
    thanks in advance
    PS: sorry for bringing up an old thread, i figured why start another....
  5. Member SaSi's Avatar
    Jan 2003
    Hellas
    If you can open the AVI in VirtualDUB, then go to the menu:
    Video--> Select Range
    and from there select the range from frame 1 to frame 9737 or so.
    If this fails, then cut the range a bit shorter (~9735 or so).
    As soon as done from that, select a new range (9740 ~ end)
    If you have a crash again, then redo the selection cutting off the offending frames.
    And bear in mind that this is most likely not a VirtualDUB problem. Most probably your AVI file has a corruption or the xVid codec is not the right version for the AVI file you have.
    Note: Don't go around installing codecs, or you might bring your whole system to an unusable state regarding playing back video...
  6. Yeah, I am also having similar problem except in module ntdll, and I am using XVid codec. If anyone knows the solution please enlighten us.
    Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
    Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3
