I have two questions. One is how do you create chapters in Adobe Premiere and then how do you do make your dvd's to where to have screen selection options. I assume you have to do both of these things for creating screen selections on your dvd.
My second question is, can you put the same created video on the same dvd multiple times so it will continue to play over and over and over or is there another way to make the dvd play continuously. The reason I am asking such a odd question is that I have a wedding demo that I am going to be playing at a Bridal show this weekend and I wanted it to play continuously instead of having to keep hitting play every 20 minutes, because it is only 20 minutes long.
Anyone that can answer either question, your help is greatly appreciated. Thanks so much!
You can't create chapters per se in Adobe Premiere (normally you leave chapters up to the authoring program), but you can place markers on the timeline. I'm not how to do that, as I haven't tried it yet. I believe that some encoding/authoring programs can interpret the markers as chapter marks. As far as your second question is concerned, you don't have to burn multiple copies of your video but you do have to find an authoring program that allows you to loop the video. I have Sonic's ReelDVD and I can put a video track on the storyboard. I can then set up the "Next" action (when the user hits the Next Track or Skip Forward buttons on when the video ends) so that it just points back to the same track. I'm not sure what other authoring programs can do. Sorry I wasn't more help.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
Hi jones_randy,
erayboul is right: Premiere don't do the chapters, the authoring program does. Also right about the looping. I believe from memory (sure I've seen it, though not used it) that TMPGEnc DVD Author does looping.
Hope that helps. Good luck with the demo...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
need help creating a DVD
By pike8 in forum Authoring (DVD)Replies: 3Last Post: 15th Mar 2012, 10:45 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
creating a dvd out of Premiere Pro CS4, proper settings?
By burrowsfan in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2009, 14:47 -
creating a border in premiere
By devdev in forum EditingReplies: 5Last Post: 15th Jan 2008, 15:40 -
Creating DVD
By KrazyCanadian in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2007, 02:19
