What type of cases are ok for storing DVD discs?
Space is an issue, I don't want to use black dvd cases - they take up too much space. Are these from SVP any good ?
They have a soft cloth centre to protect the disc better than any other PVC sleeve we've sold. because the cloth centre divides the sleeve in two, it also allows for safe storage of 2 discs in one sleeve!
Regards
pap_1 -
Yep, I've used those sleeves before - the fabric inner is great for holding two discs away from each other too.
The only downside is the holes for putting in a binder - the punched out bits are usually still attached in each sleeve when you get them and pop out with a mind of their own making it look like you've got really bad, mutant dandruff... !
Seriously though, they are very sturdy and fairly presentable. If you're strapped for space or too tight for cases (like me), you could do a lot worse than those. Buy away. -
SVP sell metal flightcases with those things inside all with index cards on rails. Can hold about 200 discs. Really neat and tidy and only vost £12.98 for the 200 disc model
DVD Storage Cases
By Tenacguy in forum MediaReplies: 6Last Post: 10th May 2010, 19:43 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 12:15 -
Blu- Ray Storage cases
By fredreed in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2009, 15:47 -
DVD/CD Jewel Cases
By wulf109 in forum Off topicReplies: 3Last Post: 23rd Jul 2008, 18:13 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 05:32
