When I capture an avi with vdub from a vhs, I get this hiss noise or extra like background noise. This does not happen when I use the same settings for live capture or from a vhs that is commercially produced ( like one ya rent or buy). I have a wintv go card, I use audio select,I checked the audio level, nothing fixes the problem. I used cool edit like cart wheel said, but no matter how much I zoom here and there and everywhere, I don't see the almost straight line that represents hiss. for some reason If I use my crappy USB Dazzle dvcII there is no hiss,but after encoding there is an Echo like an extra loud digitized echo noise. after I encoded a vdub capture, there is still the hiss, I've used all the noise filters in vdub and on tmpgenc, still no good results. Before I used to have a problem with the video, now I got the video looking good,but now the audio is giving m a problem. if you go to http://briefcase.yahoo.com/bc/nick101181 I have a clip with the extra noise in it. Please Please Please help me find a way to fix this please??????![]()
*bump*
ok is it chroma noise or hiss or what? come on someone help me out here. I have no more hair left to pull out now
change your osund compression to pcm 44,000 172k then in your mixer set your record level to half of the slyder bar.
record a silent bit of the tape before the main movie, then open up the wav file in cool edit (extract the wav with vdub> save to wav). Select the silent bit at the beginning, then go to transform>noise reduction. Get the profile from the selection. Don't click OK yet. Cancel out then select the entire wav (ctrl+a), set the amount of reduction to 60-70 %, then click ok. A long time later
save the wav. Then add this back to your original movie.
vhs video capture bad sound
By lulu15 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2011, 20:59 -
avisynth -> imageSource + sound (4min) = 40 sec video in vDub
By adom in forum Video ConversionReplies: 4Last Post: 22nd Feb 2011, 17:53 -
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 16:24 -
VDub setup for VHS Capture
By HDClown in forum Capturing and VCRReplies: 16Last Post: 27th Apr 2010, 03:48 -
Vdub filters on my HI8/VHS before Authoring..
By nopk in forum RestorationReplies: 6Last Post: 8th Dec 2007, 17:34
