I was just wondering if I purchased the combo pack with the dvd author and the encoder will I get a serial to unlock both or will I get a special link to the download.reason I ask is because theres nowhere to put a serial or register tmpgenc encoder. Any help would be appreciated..I just wanna make sure before i buy.
T.
serial numbers, looks like.
check this link:
http://www.pegasys-inc.com/en/download/
If no further replies here, suggest an inquiry either to pegasus via email or a post on their user forum....
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 22:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
