Hey to cut a long story short i use TMPGEng and have done for a while iconvert my movies with it fine
now i had a couple of movies to convert over the weekend but tmpeg just froze when i did them so i changed Environmental settings VFAPI plug-in and right clicked on the DirectShow Multimedia File Reader and increased the priority. that worked fine.
now when i go to view the converted movies theres no sound then after 1 min it freezes in all the media playersi use and it gets worse, all the converted movies i used to watch which did work fine now no longer work and the same problems occur, i can view them in avi format any even when i turn them into vob files just not in mpeg format
please help
Results 1 to 1 of 1
Major synchronizing problem please?
By tendra in forum Video ConversionReplies: 2Last Post: 31st Aug 2010, 12:28 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 16:18 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 12:49 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 09:30
