  1. Will a DVD-R, with a movie, be able to play on a Playstation 2?
    The media that I will be using is the Maxell 'green' media DVD-R
    My DVD Burner is the Pioneer A05
  2. I've successfully played a Ritek DVD-R and a Memorex DVD+RW on my playstation. Those are the only two formats I've tried.
  3. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Depends on the condition of your PS2.
    I own a version 1,3,4 and have access to a version 7 and 9. DVD-R plays in all of the above versions, but 1,3,and 4 won't play DVD-RW.
    The version 1 is really picky about the brand of media. Only plays Ritek 20-25% of the time, even then it hardly finishes a whole movie without skipping. Taiyo Yuden has had a 100% succes so far.
    The early PS2 versions (1-4) also have some issues with certain DVD Authoring programs.
    Some of these problems may be fixed with a firmware upgrade, if Sony would make it easy enough to find
  4. My PS2 plays Traxdata DVD-RW just fine. Tried a Fujifilm DVD+RW with no luck...
    Dec 2002
    Pennsylvania
    I have version 7 and it's played everything I've put in it including TDK, Verbatims and most Princo's.
    Jan 2004
    Houston, TX
    don't know what version of ps2 i have, but mine reads -r and +r
  7. I have version 9 and it play DVD-R and DVD+RW just fine other than that (DVD+R, haven't tried DVD-RW) it won't play at all and also will make some ugly noice when try to read those discs.
