    Dec 2003
    Florida, USA
    Hi everyone, I made my first menu on DVD-Lab 1.3. I followed the instructions in this guide http://www.mediachance.com/dvdlab/Help/quick.htm and I'm having trouble compiling.
    1. I combined different chapters from 3 DVDs with DVDShrink, done (very simple, DVDShrink is the bomb!)
    2. I burned it with Nero 6 to make sure it worked and it waplayable in my Toshiba DVD player. It worked fine, and all 3 chapters were there.
    3. Then I decided to create a menu for the same DVD+R I just created.
    4. In DVD-Lab I used the file browser to add the .VBO files (that DVDShrink combined), I chose option"use directly with out demultiplexing.
    5. I created the background for the menu and the P"Play movie" link.
    6. I draged and dropt the first VBO in the movie box, and added my chapter points.
    7. I did the same for the 2nd and 3rd VBO ( I had to create a "movie 2" and "movie 3")because it did not allowme to drag and drop the 2nd and 3rd VBOs in "movie 1".
    8. I added a scene selection menu for each "movie 1, 2, 3". Scene selection menu for movie 1 had the link for scene selection menu for movie 2, witch had a link for movie 3. (Just like a book, one page takes you to the other).
    9. Last, I compiled the project to a temp folder and the following sttings were checked: Main (fast, DVD compliant), NTFS safe color, reduce jitter, force audion for all vovies.
    The whole think was oly 700MB (that is all I started with, just for testing puposes). It compiled in about 2 minutes. Using real one player (with is what I use to check all my vobs before, the "video_TS.vob file is nothing but gary vertical bars, the "VTS_01_0.vob" in the scene selection menu for movie 3, and the "VTS_01_1.vob" was a DVD-Lab LOG that said "movie goes here".
    Does anyone have any idea of what jwent wrong, I followed the guide step by step.
    Thanks for any help!
    Lord Pitufo
    A Little Green!!
    TDK Indi 440N
  2. Look at the compile dialog box and make sure that TEST COMPILE(replace movies with test image) is not checked. It's toward the bottom of the box under Compile Options.
    Dec 2003
    Florida, USA
    I did, the only thing are checked are the ones list before. Thanks, any more sugestions.
    Lord Pitufo
    A Little Green!!
    TDK Indi 440N
