I have connected my Daewoo DVG-3000N dvd player to Panasonic 27" TV thru an S-Video cable. I am not getting any audio at all.But by using A/V cables it is working fine.
Any help in this regard will be greatly appreciated.
You have it connected properly at this time. The S-Video is for the video only, it doesn't connect the audio.
Than you so much scottwiggins.
BTW-
That means s- video cable just replaces my normal video(yellow cable) and i have to use audio(red and white)cables as usual. Is that right ..? -
yes....unles you have digital coax/fiberoptic cable ....but then you have make sure you audio receiver supports digital.
Daewoo DF4100P
By hillneerg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Feb 2011, 12:06 -
DVD recorder Daewoo DL-3100
By Leonora in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Apr 2009, 07:35 -
Hack the Daewoo DS-K965
By sonquilombo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Jan 2009, 19:08 -
DVD Daewoo DS-K960U
By TonitoDJ in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Oct 2008, 10:08 -
Code Free does not work daewoo dvg 8300 se
By ramona in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Feb 2008, 11:52
