Hi,
I'm looking for a video capture card to replace my UK Panasonic DMR-E100H dvd recorder. I'd like it to be able to record from both PAL and NTSC tapes to dvd. I'd also like to record in high dvd quality, 10 megabits per second or more.
I have a powerful 3mhz AMD chip, massive hard drive and 1 gigabyte of DDR RAM.
Thanks for any help
The Panasonic DVD recorders do such a superb job converting VHS tapes to DVD format that many folks have noted the DMR-E(whatever) series actually *improve* the quality of program material transferred from VHS to DVD.
You're not going to find any computer capture cards that do as good a job. The Canopus or Datavideo do a good job but not as impressive IMHO as the Panasonic DVRs. Various folks tout the quality of ATI AIW cap cards but they can be expensive, and depending on your hardware/software the ATI might or might not work well. And the quality still isn't as good as what you get from a Panasonic DVR. -
I believe that per the DVD specification the maximum bitrate is 9.8 Mbps and that includes the video plus all audio and subtitle/subpicture streams.Originally Posted by jedi55Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
Hi,
Thanks for the quick reply. I have an Nvidia 5900 card, so I can't use Ati. The panasonic is great, but most of my tapes are NTSC. I have a Sony PAL 60 video player and my dvd recorder does'nt like PAL 60. Are there any cheap pure pal converters? If not, could you please recommend a PCI capture card.
Thanks -
These are a very good brand:Originally Posted by jedi55
http://www.viewcast.com/products/osprey.html
Notice that the high end models are 1000's but they do hardware MPEG encoding, DV, Audio/Video In and out.
For cheaper solutions - there are a number on sale at www.compgeeks.com
Getting Footage from SDHC Card from High-Def 1920x1080-60p in Best Quality?
By bmccollum in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 20th May 2010, 00:12 -
Help Finding A High Quality Capture Card
By NMeade in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 21:00 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 21:53
