Any of you have digital voice recorders?
Im looking for one that records voice but then give you the ability to export the recordings to your computer to save for later.
Macmall.com swears that the Olympus W-10 works with both PC and Mac
so i buy it.......... NOTHING. no mac support. Plugging it in does nothing but have Hardware profiler say a usb recorder is attached.
so........ anyone have one that does work?
thanks
I don't have one but the Olympus site has OS X and OS 9 software downloads for several of their digital voice recorders. But not the one you have. The online guide for yours says that Olympus is reportedly working on Mac software for it.
yea i noticed that. the ONLY one they make not in the download list.
crazy no.
thus my reasons for asking if anyone has one of those on the list and can recommend one. -
You have to get the more pricey Olympus DS-330 to get full Mac support. It ships with software needed to read their sound files.
Works fine and is a great voice recorder. Got mine last summer for $125, I believe, on-line. -
yes just got off the phone with olympus
appears that is the CHEAPEST one that works on mac. they go up from there...
im watching my online sites to see if i can get a good price
thanks everyone -
Off the top of my head I can't remember which Olympus model, but one of them works with iListen to convert your voice recordings to text. If that's what you want to do, be forewarned that ambient sound screws up the voice profile. And if that isn't want to want to do, then ignore this warning.
william -
would be SWEET......... but mostly im interested in saving the recordings for use later.... since these guys can only hold 3-6 hours in the price range i want to spend.... more than 2 lectures and im full! so i need to export them to my mac
im watching the 330 on ebay... lets hope i get it! -
Yes, it was the DS-330 that was recommended for use with iListen in a MacWorld article. though I haven't tried it. Can't remember what month it was, but they also discussed the best settings on the recorder for use with iListen.
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 17:00 -
Portable Voice Recorder
By therock003 in forum Capturing and VCRReplies: 3Last Post: 6th Dec 2010, 16:56 -
good portable voice recorder to use when shooting
By greymalkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 28th Aug 2010, 16:15 -
Best options for voice recorder for FM
By happydog500 in forum AudioReplies: 1Last Post: 6th Mar 2009, 23:03 -
voice and music recorder
By zoobie in forum AudioReplies: 9Last Post: 17th Mar 2008, 10:51
