I am using the WinTV PVR capture card and it is working great except for a couple of things.
First, just a few of the cable channels do not come in very well. Channels 4, 5, 16, are the most difficult to see. Most of the channels are crystal clear. I am using a splitter and the channels on the TV are perfect but not on the PC.
Just wondering if any of you guys had experienced this and if there is a solution.
Thanks...
Eric Hill
President
J & E Designs, Inc.
Muscle Shoals, AL
hille@wlv.com
Try connecting the cable without the spliter.
Does this solve your problems?
David -
I've tried that and still have the problem. Could it be too much interference from the other wires and cables going to the rear of my unit? There are a few!!!
Thanks for your prompt reply.
Eric
I have the same problem
Channels 7,11,12(12 is really bad clear barely visible lines, but on pc shows up really bad) it sucks Cause I want to capture Dark Angel from channel 12, and angel from channel 11. Anyway I found that sometimes the 2d cleaner filter for Vdub helps some, not totally but a little bit. I got a filter called vhs tools or toys or something made by this guy named flaxen I think. I am still trying to fiugre out how to work it. see ya
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 08:43 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 06:54 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 13:21 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 10:39 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 17:20
