  1. Can you listen to DTS audio DVD's on your PC?
    I'm using NVDVD, DD5.1 is fine, I can't find any info on DTS audio - do I need a codec, and if so where can I get one!
    Dave
  2. Member Kurt S's Avatar
    Jan 2003
    You can do it with WinDVD Platinum.
    http://spt1.intervideo.com/php/searchnext.php?pid=62
  3. Mmmm, so it does - thanks for the info.
    Maybe one day NVDVD will catch up!
    Why isn't it just a matter of adding a DTS codec?
    Dave
  4. Member Kurt S's Avatar
    Jan 2003
    Minnetonka Audio sells the encoders but I'm not aware of anyone selling just the decoder.
    http://www.surcode.com/low/low_index.html
