Hi
when i author my DVD, DVD Labs puts in an extra menu with a striped picture, how can i get rid of this?
when i put it in DVD Shrink it comes up under menus with this striped picture as Title Menu and the Root menu as VTS 1
played on my stand alone the striped picture is played first before the menu comes up, very annoying
can anyone help me on this?
thanks
more info
when i author a DVD picked in DVD Labs as Normal VTS Menu
then setup my structure including a root menu and author ok
when i play this DVD it first shows this black & white striped picture
just short but it is there and annoying.
when checked in DVD Shrink the DVD structure shows as:-
DVD
-----Menus
----------Title Menu
---------------English
--------------------Menu 1 * striped picture
----------VTS 1
--------------------Menu 2 * my root menu
this happens on two different computers
need help on this, thanks -
I use DVD-Lab frequently and have never run into this problem.
At what point does it add an extra menu? When you start creating the project, or does it add it after you compile?
If you can see the extra menu, can you just select the menu and press the 'delete' key?
Tearren -
Hi Tearren,
it only comes up with this "menu" after it has been compiled thats why i cant delete it.
if i make a new project with only a root menu and 1 video it still puts in this extra "menu" i thought it might be a setting but could not find anything.
if i add a VMG menu then it is gone and the VMG menu is in its place, it looks like DVD-Lab is looking for a VMG menu ALL the time even if i start a Normal VTS project
and on two different computers puts me off a bit too
Problem with DVD Author
By JCWBobC in forum Authoring (DVD)Replies: 1Last Post: 12th Jul 2009, 01:55 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
Digital Labs DL 840PD
By Arte et Marte in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jul 2008, 10:09 -
Creative Labs - ZEN Player Format???
By GT Music in forum DVD RippingReplies: 1Last Post: 11th Jan 2008, 22:11 -
WMV. Problem to author a dvd....
By mngwdw in forum Video ConversionReplies: 2Last Post: 27th Jun 2007, 15:00
