I have an 6.7 Gb Iso which I want to burn onto an 4.7 Gb disc.
Is it possible to mount the image in Daemon or similar program and then use DVddecrypter or DVDshrink to rip it from Daemon as if it was a real DVD?
Your method should work as Daemon tools will mount the ISO file, then just use DVD shrink.
You could also extract the image with iso buster, and then shrinkJust shut up and listen dumbass -
Yep, works great. It's how I do Episodic disks as well as disks of 'Extras'. It's also how you can combine 2 disks to 1 with no menu.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
As Gaz said...yep, that will work perfectly and your rip speed will be unreal.
How to shrink a blu-ray iso file & keep menus
By neworldman in forum Blu-ray RippingReplies: 7Last Post: 5th Jan 2014, 20:35 -
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Shrink ISO of BD-50 to BD-25?
By ADigitalMan in forum Blu-ray RippingReplies: 2Last Post: 3rd Dec 2011, 19:35 -
DVD shrink and ISO playback with WDTV
By neworldman in forum DVD RippingReplies: 3Last Post: 14th Apr 2010, 13:40 -
DVD Shrink .ISO/.MDS issues...
By AGenius in forum DVD RippingReplies: 6Last Post: 19th Mar 2008, 12:53
