hi everybody,
not so long ago I have created my own dvd , I burned it and it plays in my dvd-player there is only one problem .... the player plays it high speed !!! and that is not good.
i used dvd-lab to create the menu so my question is what do i need to change in the options or whatever to let the dvd-player play it normal speeds ? has it something to do with the bit-rate ?? please help me.
thanks wouter goud
Hi goud3,
Don't know what you're problem is, but I do know that the bitrate relates to the quality of video (mostly) and not the speed of playback.
Sorry I couldn't be of more help, but I hope that at least means you don't go on that particular wild goose chase.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 17:11 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
Winavi Runs Slow On Old Computer Any Way To Speed It Up
By DJboutit in forum Video ConversionReplies: 6Last Post: 3rd Jan 2010, 18:36 -
Help Re-Authoring DVD to change one option
By Smack2k in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2009, 00:06 -
Anybody know how to change the speed of DVD Writer?
By mommyc in forum DVD & Blu-ray WritersReplies: 30Last Post: 25th Sep 2007, 16:58
