Okay, so I want to add a chapter points based on frame numbers in my video (48289 frames at 29.970fps), but DVD-Lab says that the chapter file should be in the format...
HH:MM:SS:CC
where CC are cents. What the hell is a cent?! Is it 0..99 where 0 is 0 seconds and 99 is almost 1 second?
Virtual Dub gives points in a video as HH:MM:SS:MS where MS are milliseconds. It also gives points as frames too. My question is when I find a frame in VDub where I want a chapter point, how do I go about converting that into the format that DVD-Lab uses (so I can import a txt file with all my chapter points). It doesn't seem to support just putting frame numbers in that chapter file ala "CellTimes.txt" with IfoEdit.
So, let's say I want a chapter at frame 36182 (0:20:07.274 in VDub). Then would that simply be 00:20:07:27 in DVD-Lab -- dropping the third digit of msecs to get "cents?" Thanks!
Results 1 to 30 of 46
- Mike Young
My Clay Animations -
DVD-lab imports chapters in this format: 00:00:00:000
I have no idea if "cc" is the same as "ms". Have you tried importing them from Vdub to see what results? A simple text file like this works fine:
Code:00:09:41:000 00:10:16:000 00:33:21:000 00:59:59:000 01:03:19:000 01:16:06:000
I tried using VDub's format. It doesn't seem to work as the exact points that I picked are sometimes 2 seconds off and the amount that they are off is not constant when I pick times (via imported .txt file). So I tried deleting the time it chose and picked the time it chose and then it picks a different time again! Selecting exact frames where you want chapters seems broken to me, unless I'm completely missing something.
It was so simple with IfoEdit -- just type in the frame numbers where you wanted chapter points. Why doesn't DVD-Lab allow you to select exact frame numbers?! Perhaps a good question for Media Chance. This is currently my only issue with DVD-Lab. Everything else I LOVE about it, but this one thing is ticking me off! Anyone? Thanks!- Mike Young
I might be wrong, but I though the last numbers refered to the frame
HH:MM:SS:CC .... so in NTSC, with 30 fps (well, 29.979), the CC number would be 01 to 30, which would tell you which frame your are on for that second of video. -
That cannot be the case because there isn't a whole number of frames per second in non-drop frame NTSC, it's 29.97 frames per second.
00:00:00:29 could not go to 00:00:01:00 because 30 frames is not 1 second in non-drop frame NTSC, it's roughly 1.001 seconds. The cumulative errors in round off would mean BIG problems!
In addition, the CC field seems to be 0..99, making the term "cents" make sence.
I'm still stumped. This seems like such a basic thing -- the ability to specify exact frames for chapter points. IfoEdit did it. I NEED the capability to set exact frames as it would be pretty cheesy to have a chapter point just before or right after a shot cut. DVD-Lab MUST allow for this somehow!- Mike Young
try downloading chapterxtracktor and following what it says for #6 on this guide http://www.mpegit.net/eng_dvdr_cce_basic.php to get the chapter frames. highlight them and save, then see if it will let you import them. i doubt it, but its worth a shot.
kenshin,
I'm making a DVD from scratch, not copying one already made.
andkiich,
I tried indexing the frames, but it still expects me to input chapter points in HH:MM:SS:CC format. Even after frame indexing it is still strangely inaccurate and inconsistant when I specify chapter points from a .txt file. I'm surprised no one so far has an answer to this. This is REALLY a basic thing to do! But I'm far from giving up. Keep the suggestions coming! Thanks!- Mike Young
If your making the DVD from scratch, why not manually add the points in DVD-Lab instead of importing them? Still curious to the current problem though.
Try making your chapter points in DVD-lab at the same points as Vdub and then export them to a file to see what the differences are in the formats between the two programs. Then import both files into DVD-lab again to see if they import correctly and what the differences are. -
Originally Posted by MYoung
Stop being stubborn and input your chapter stop numbers as hours:minuteseconds:frames (1-29 if it's NTSC video).
It cannot be, because you don't understand timecode. Do a search for "drop frame time code" and you'll get it.
In the meantime, try it and see what happens rather than spending so much time arguing about it.I don't have a bad attitude...
Life has a bad attitude! -
It might just be me, but why not just view the video in the preview window and insert the chapter points where you want it? You can visually see where you want the break. Who gives a damn about the timecode? If you want accuracy, after you set the chapter point use frame indexing.
"Can You Dig It!" -
proggy,
I don't want to maunally add chapter points because I cannot get frame accuracy when I scan through the video. It skips 15 or so frames when I press the left/right arrow keys in the preview window. Do you know of a way to get frame accuracy when stepping thorugh the stream?
leebo,
I would input my chapter points as HH:MM:SS:CC if I knew how to convert to it from what VDub gives me -- HH:MM:SS:MS or frames. And yes, I've tried it which is why I'm asking about it! As for reading about drop-frame, I don't see how that matters since I'm working with non-drop frame. Instead of being a snob about how much you know and how little I know, how about you explain it or just bite your tongue and not post on this thread, alright?
I guess I'm off to play with it some more. Thanks for the help and patience everyone. As for you leebo, I can only thank you for help. Try working on the "patience" thing.- Mike Young
If you encode your mpegs in TmpGenc, you could try the 'detect scene change' setting. This inserts an I-frame when it detects a scene change. Or you have to encode each scene seperatley to ensure you get I-Frames exactly at the start of the scene. -
I have not found any authoring tool yet that will allow chapters anywhere but I-Frames.
If you think about it, when you jump to a chapter, the mpeg decoder needs an I-Frame to start decoding, so restricting chapter points to I-Frames makes sense.
from http://dvd.sourceforge.net/dvdnav-docs/dvdnavissues.html
A VOBU (Video OBject Unit) is a small (typically a few seconds) of video. It must be a self contained 'Group of Pictures' which can be understood by the MPEG decoder. All seeking, jumping, etc is guaranteed to occurr at a VOBU boundary so that the decoder need not be restarted and that the location jumped to is always the start of a valid MPEG stream. -
Those I-Frames are beggining to get in my nerves, i too have the same problem, i CANT set a chapter EXACTLY where i want it. It can only be placed on the I-Frame which can be a loss of 13 frames from the point i want the chapter to begin. Why is this happening? How in proffessional DVD movies they have no sutch problems??? I see exact chapters points on other DVD films. How can i bypass this problem within DVD LAB???
Originally Posted by zoranb
I believe that if i were to encode each scene differently then i wouldnt be able to make one scene selection menu for the whole movie (im using DVDLAB-can i do it??) it seems that heyd be 10 or more different scene selection menus each having the chapters of the scene i encoded seperatelly...and so on...
You could do it encoding each scene seperateley and then joining them all into one big mpeg. Possible sync problems though.
The proffesionals encode each scene seperatley (often using different encoder settings appropriate to the scene). As each scene will start on an I-Frame, thats how they can set their chapter points exactly. You too could do the same if you have the time.
I might be misunderstanding, but I don't know. -
Originally Posted by Dr_Layne
Als I have noticed the chapters do slide back or forward up to 15 frames when adding them. I don't think this is DVD Lab, but the difficulty of dealing with MPG2 files. They are no the same animal as film and video footage.
When exact chapters are important, I burn my disc on a RW, then view it and make notes on which chapters if any need reapplied. Leaving DVD Lab open the whole time. Fix the chapters that are off, and re-compile dvd. I managed to get all 8 chapteres exactly right. It took me 3 hours, but was worth it on that project.
Jeff -
I dont understand what u mean by "I burn my disc on a RW"
How do u fix chapters since they move by 15frames? How canu be exact? -
I re-complie the dvd, and burn a new disc, check it and repeat if needed. It takes a few trys, but I did end up with perfect chapters.
Because when you drop a chapter in where you want it, sometimes the frame will jump out of place, sometimes not. If you knew it was going to do this in advance, you could better predict where it will default to, and thus get better chapter placement prediction. I am learning to predict this effect in advance. And redoing chapters with this in mind has helped me.
I have nailed a few chapters that were bot landing correctly by redoing them. It took some time, but it worked.
Jeff -
I believe that it is difficult to place chapeters in exact right place because it is mp2 compressed video you are working with. That is not DVD Labs fault.
Jeff -
@hiptune, I think the point zoranb is trying to make is that no matter what technique you use, chapters points must always be on mpeg I-Frames which default to every 15th frame for NTSC video. So no matter how hard you try, the nearest you can get to the desired frame is somewhere within those 15 frames. You might be lucky and get the chapter exactly where you want or it could be anywhere up to 15 frames out.
If 15 frames (about 1/2 a second at NTSC frame rates) is close enough for you, thats great, but some want frame accurate chapter marks. -
Originally Posted by bugster
DVD Lab offers some very slick features at perhaps a lower cost than found elsewhere, but it also has some limitations. Exact chapter placement with ease is one of those limitations.
Jeff -
hiptune thanx for posting in, but only bugster has caught my meaning concerning the exact chapter point precision due to iframe disability in doing so. So bugster i take it that there is no way of setting exact points in DVDlab or any other "more proffessional" app for that matter! Is there a way i can set chapters on Premiere by any "special" means,so i can avoid placing them when the video is compressed (m2v)?
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 18:56 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 07:38 -
How do I set chapter points in an already authored DVD?
By midders in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2008, 17:57 -
question about how to add chapter points to already made DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 24th Apr 2008, 14:44 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39
