Hi. Somebody remember the movie "Scream"? remember the little machine the killer used for changing his voice and talk like other person?
Well, im looking for a computer software to do this nice trick. Does anyone know where to find it?
thanks.![]()
Results 1 to 10 of 10
I am sorry, I missed Scream, as if a horror movie does not have Sigourney Weaver in it, I tend to miss it (Rowr!). What exactly was the effect?
Hello. -
If you are talking about filtering a voice out of audio, changing
it, and putting it back in, Give Up -
No, im not talking about filtering the voice from a music cd or something.
I mean just voice, a wav file for example, with my voice recorded. I want to modify it, and make it sound like the voice of a specific person with a sample or his/her voice. ok? -
If you want to simply take a wav file of your voice and change the way it sounds, any wav editor can do that. Goldwave is shareware in pretty good.
However, if you want to manipulate it automatically based on another audio sample (someone elses voice), then I have no-idea. In fact I doubt it can be done with everyday sofware. -
there is software I've seen that will change pitch (high or low) and formant (the tonal character of the voice), but it's expensive, only for Mac and I don't remember the name off the top of my head.
give me a day or two and I'll find the program name. I'm pretty sure it was a plugin for Digital Performer. most any audio program will allow you to change the pitch of a voice recording, but formant change is something else, and it sounds like that's what you'd need.
as far as taking samples from one person to use as a guide, and making your voice sound like that person, I've never seen it.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
hi i'm interested in these too can you give me any info you know about this.
Po dobre BEZdelnik, ot kolkoto bez praznik!!! -
http://www.audio4fun.com/recording-studio.htm
http://www.blazeaudio.com/products/voicesfx.html
might be something your looking for -
They also make telephone devices for women who live alone. It makes their voice sound like a man's voice. They are also not toys by any means and are a bit expensive.
Try here > (vocoder)
http://www.analogx.com/contents/download/audio.htm
How to Change your Voice to another normal Voice
By UmmAddan in forum AudioReplies: 2Last Post: 21st Jul 2011, 17:00 -
Any good voice changing editing software?
By overloaded_ide in forum AudioReplies: 7Last Post: 14th Dec 2009, 21:39 -
voice over
By revid in forum EditingReplies: 1Last Post: 29th Oct 2008, 06:19 -
voice morph
By MadMax_911 in forum AudioReplies: 11Last Post: 11th Aug 2007, 14:58 -
Altering a voice, what can be done?
By Rudyard in forum AudioReplies: 1Last Post: 10th Jul 2007, 01:33
