    Nov 2003
    Houston, TX
    Hey, i got some .mpg files i want to join, how would i do this? I already tried tmpgenc but was having trouble with it, any other idea's?
    thx, josh
  2. TMPGenc criteria:
    Video Parameters -
    Picture Size The picture sizes must be equal.
    Frame Rate The frame rates must be identical.
    Aspect Ratio The aspect ratios must be identical.
    Bitrate The bitrates may vary. If the bitrates vary between the files, a variable bitrate is used.
    VBV Buffer Size The VBV buffer size is set to be the largest required for the file.
    Audio Parameters -
    Sampling Frequency The sampling frequencies must be identical.
    Channel Mode The channel modes must be identical.
    Bitrate The bitrates must be identical
    Think your files will need to meet above, particularly if you intend to burn a dvd.
    Apr 2002
    The State of Frustration
    Or drop them all into Video Studio and burn them.
    Hello.
