    I am backing a movie and have done all the editing on the menus and took everything out that i want but now i can not shrink it. Movie has 12 titles including the video title. To play the movie titles 1 & 5 are all that is needed. I used DVD Decrypter in file mode to theses titles. I finished changing the menus with menuedit and now i am a little over the limit and need to compress. DVDShrink 3.1 tells me that it can not find the other titles and can not continue. I've tried renaming title 5 to 2 but then dvdshrink ask for title 3. If i were to just rename them that would cause problems with my menus then Right?
    How do i fix the ifo or do whatever to fix this problem?
    syoung
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you must rip all the files and feed those to DVDShrink
    you can use 2COOL's guides along with my flash guides to remove the VTS_02 to VTS_04 VOB's but still maintain the DVD structure
    that way DVDShrink will then accept the files
    at the minute the VIDEO_TS.IFO refers to the VTS_02_0.IFO and that is why DVDShrink cannot continue as it isn't there
