Hello Is there a way to burn OGM files on panther.
I have ogm file and I am trying to burn with toast but I do know that it is a windows extension.
So someone![]()
Results 1 to 10 of 10
it isnt a windows extension, its a video container. Burn it as a data disc. Should work fine. Are fyou just trying to back it up? oir watch it on a standalone divx/xvid player?
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
most likely you will have to convert it to a file Toast can like
is it playable with Mplayer OSX
if so its convertable using mencoder and you just need to run it through a conversion then let toast do what you were trying to do earlier. -
mencoder is something ffmpegx and other converters use.
you have to see if the GUI MplayerOSX will play the file first...
http://mplayerosx.sourceforge.net/ then click DOWNLOAD -
Can burm it like data en burn this file on a window-pc burning using nero of something else because it has not worked with some mencoders so I am trying the the bad way using A PC
I read that 5 times and still dont know what you were trying to say!
translation:Originally Posted by keeskishore13
He can burn it as data using the burn this file under Nero (5.5?)
on his windows PC. The file has not worked with some of the mencoders
he has used on the (Mac) so he is using the dark side of the force,
master galactica, by trying it on a PC.
(items in parenthesis) are my assumptions from what little I know
of the Dark Side, master.
8) -
enought to read and understand the code apparently......... i see it now though
you are now longer referred to as young padwan terryj
you are now referred to as jedi terryj
thank you, master galactica!
you and master tgpo have be most gracious!
.ogm file
By d_animality in forum Authoring (DVD)Replies: 2Last Post: 29th Aug 2011, 08:19 -
How to Convert OGM!?!
By SamohAD in forum Video ConversionReplies: 6Last Post: 19th Mar 2009, 18:42 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 19:08 -
.ogm to DVD
By Faty100 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 10:14 -
OGM remuxer?
By Colmino in forum Video ConversionReplies: 1Last Post: 25th Nov 2007, 13:27
